what is this?
hammerdownracing
New to the forum. I just picked up this 98 GT. it is mostly stock. I was looking under the hood and this part on the crank pulley looked odd. I don't believe ford would use blue anodized parts from the factory. was wondering if anyone had any ideas what was up. This is my first mod motor so it is all new to me.
Silver95bird
one of those cheezy "timing adjusters" from about 1997?
i feel like i stepped out of a time machine. Did Austin Powers get a sequel yet?
Sent from my moto z3 using Tapatalk
H
hammerdownracing
that doesn't sound good. It is a little doggy out of the hole. that could be from the timing if they changed it. any idea what it takes to put it back to stock?
RAU03MACH
NEW MEXICO
Have not seen one of those in a long time
aftermarket kit for timing someone added
the pick up should be inside the chain cover and so should the part with the pick up gear on it
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
You need a stock balancer bolt. Remove the bolt and timing adjuster, remove the bracket holding the crank sensor, then put the crank sensor in the stock location and install the stock balancer bolt. Easy peasy
96blak54
Staff member
Lawrenceburg Kentucky
And then youll find out if that front cover has been removed and timing wheel is missing...lol. Thats how my luck runs!
Sent from my SM-G900P using Tapatalk
H
hammerdownracing
now that I know what it is I have found them online. looks like it is a steeda brand. when I get time I will pull it off and see if it makes any real difference.
RAU03MACH
NEW MEXICO
I really don't think so , but it is an aftermarket , like say you wanted to convert it over to carb set up or relocation , just a couple of samples of having it
