what should TPS be set too?
ever since I did my trickflow stage 1 HCI swap my idle has just never been happy much under 8-900 rpms and just sounds a little fast at that number. When I adjust it down it has a hard time starting up cold and will occasionally bog when I take my foot of the gas. I thought I remembered reading somewhere that the TPS needed to be set to something just above the factory setting and was wondring if that was true, if that could be it, and what that # was?
ProKiller
PA
agree with White, but rz is correct as well. if the tune says you are set at X then you must stay at X.
95opal
Dont worry about adjusting the TPS voltage the ecm will adjust to a base voltage when the throttle is closed.
