I got done with the polish and puller her out for some pics. I pop the hood and I am horrified to find water spots on the bottom of the hood. Not just one or two but something has been spraying at some point. After some inspection I found the gasket failed at the thermostat housing, no a big deal. While I am in there I have also had a leak from the coolant pipe that comes up from the lower and has the temp sender it that goes to the back of the motor. I am not sure the name of the pipe but where it is able to rotate it has been leaking. I thought I saw somewhere that there was a gasket repair kit or some way of fixing it a while back.
if you look in the pic at the thermostat housing you can see where its leaking. The coolant pipe is just behind it.
I gotta get this thing on the road.... Anyone know how to fix this?
