X pipe temp and EGR tube idea
302hobronco
Washington
Hello everyone new member here. just purchased a 94 mustang gt 107k miles bone stock. The other night I noticed exhaust smell coming into the cabin. egr tube cracked at top "wrinkle" spot. after reading all the pros and cons of removing it I decided I want to keep the system intact. BUT! I don't want to pay 50 bucks for a egr tube. So here is the questions I have. I have a X pipe I will be installing soon. Can the air inlet on the Xpipe be used as the egr feed for the valve?? how hot do you think the Xpipe would get? im wondering if a high temp silicon hose can be routed so that it feeds the egr. I thought I saw a post of someone doing this but cant seem to find it now. I found some silicone hose rated up to 500deg for pretty cheap. any input on this is greatly appreciated.
evilcw311
Most Evil Member!
Louisville, KY
It’s how the Fox’s were done. That’s why that pipe is there. Hook it up and you should be fine. Not sure how well a silicone hose holds up though.
white95
Apex Junky
Prairieville, LA
Didn’t that feed the smog/air pump that then force fed the system?
evilcw311
Most Evil Member!
Louisville, KY
Can’t remember for sure. I just remember that the egr on the foxes wasn’t hooked to the headers like our sn’s. That’s why a lot of sn guys order the headers for a fox cause they don’t have the egr tube. The egr on the foxes was hooked to the factory crossover pipe
302hobronco
Washington
Thank you for the responses. I decided to just order the egr tube from LMR. The price for hose that can withstand the heat would be more than just the factory tube.
alleghenyamerican
