03DSGGT's official Winter 2015 build thread (UPDATE 5/19 POST #81)
03DSGGT
SN95 Supporting Member
Akron, Ohio
Well, its that time of year again. Time to tear into the car in search of more power, quicker E.T.s, and buttoning up loose ends. For those of you that may not remember, last spring the car dynoed at 350rwhp/348rwtq N/A. Im running the stock shortblock, TFS 38cc heads (10.3:1 C.R.) CMS stage 3 N/A cams, and the stock PI intake. I did not race last year due to not having the funds to replace my worn out slicks. The last time I raced, I had smaller MHS cams and 325rwhp/325rwtq. I ran 12.40s-12.50s on that setup with 60fts ranging in the high 1.5s down to 1.7s as the slicks were giving up the ghost.
So this past fall I ripped the interior out (once again) for a few reasons. For one, Im installing my Baseline Suspensions anti roll bar, and Im going to be welding in the plates to the floor, and I don't want any potential fire hazards. I also never got to prep and paint my Maximum Motorsports roll cage mounting plates. When I installed the roll bar a couple years ago, I was jamming on it to get it done for my buddys wedding, and a few of the details went overlooked, so with the carpet out, I can pull the mounting plates that go under the car out and paint them. Another thing that Im going to do is to scrape the sound deadener off of the floor boards. Id like to remove a little bit of weight, but Im not willing to give up A/C, stereo, etc. I don't want to ride in a tin can, so this will be some weight removed that's not too noticeable, and Im OK with the little bit of extra heat and sound from the deadener being gone:
Rear end out for better accessibility for mounting the anti roll bar:
Mocking up anti roll bar:
Inside anti roll bar plates bolted in. You can kinda see that I had to notch the plates to clear around my upper torque box plates that were previously installed. You can also see where Ive begun scraping the sound deadener off:
And the last thing interior wise that I wanted to do was to clean the seats. The car came with 03-04 Cobra seats when I bought it in '05. Ive always been careful with the seats, but owning the car for 10 years has generated some dirt. The seats looked fine, but I figured that I would clean them up anyways. I did some research and came across the Woolite method. Im glad I did, because I turned a couple white towels brown from cleaning the alcantara inserts. They look much better, and I also conditioned the leather parts of the seats as well:
Im going to make some aluminum tabs to fix the broken tabs on my rear seat headrest, and Im going to buy a Mustang cloth seat and adapt a passengers side manual seat track to work on the drivers side, so when I go to the track I can pull the heavy Cobra seats and throw the lighter manual seat in. I don't want to buy racing seats, and Im really not feeling the Kirkey aluminum seats. I want something that's lighter than a leather Cobra power seat, but is comfortable and cheap, and looks like it belongs in the car. Call me anal, but it is what it is..:tongue3:
So next up on the list is drag wheels. I used to have a set of big and little pro stars that I ran on the car. They were 15x3.5 and 15x8. I liked the look of them, but whenever I would switch from my Bullitts to the pro stars, I would swap front brakes as well, because I ran Bullitt front brakes with the Bullitt wheels, and would switch to my stock GT brakes that I modified the caliper braket to work with the pro stars. I only had to run a 1/4" spacer with the GT brakes and IMO it looked way better then running a big 1" spacer with the Bullitt brakes. But naturally, switching brakes got pretty old. So I bought a set of 17x4.5 Race Star front runner wheels and tires last winter. I found them online, they were bought and mounted, but never ran on the car, so I got a pretty good deal. Fast forward to yesterday, I ran up to Summit Racing, and bought the rear wheels and tires. I got 15x8 Race Stars with a set of M/T ET Drag slicks that are a 26x10-15 stiff wall. So Im hoping that the new slicks, anti roll bar, Team Z rear drag springs, and Strange 10 ways will get some work done at the track:
Drag wheels:
Bullitts for street duty:
SO far, Ive got a few of the loose ends part covered, I have some of the weight reduction covered, so all that's left is the more power part. Originally I pieced together a Bullitt swap for the car. I bought the bare manifold on ebay for a pretty good deal, so in my OCD nature, I found all of the pieces that were either new or NOS. I tracked down a mint throttle cable, NOS throttle body, NOS fuel rails, new alternator, NOS coolant tube, NOS thermostat hose and housing, NOS throttle braket, NOS cruise cable, and all of the corresponding swap parts. Well, right when I got my swap parts list complete, plans changed as they always do. After doing some research, it seems that the Edelbrock intake is pretty hit or miss intake for the 2 valve engines depending on the mods done to it. I was leery about using it because of the loss of low end that a lot of guys see on N/A motors. However, it seems that a few of the mod motor gurus know the right combo for the Eddy to shine based on the cam size and compression that the motor has. They claim that with the right sized cam, the Eddy will retain low end torque and have solid gains up top, and my Cushman Stage 3 cams are right in the sweet spot for the intake to work. So I bought an Eddy intake off of this forum, made up some brackets to make the stock fuel rails work, bought a 6061 elbow, and a new SVE 75mm throttle body. Im also going to run a 1" 4 hole tapered spacer under the elbow to help evenly feed the cylinders as was recommended in my research. Im also switching over to all 12 point stainless ARP hardware for the motor. I like the way that it looks, and since Im replacing the intake, Im going to do all of the bolts that mount the intake, and everything that bolts on to the intake. I will do the bolts in sections, because it will get really expensive to do it all at once:
Here are some pictures of the motor as it sits. I painted my Trick Flow valve covers Ford Racing blue last fall. Im really a fan of that look on the 4V cars, so I decided to do it on mine:
Bullitt intake with swap parts:
Eddy intake with swap parts:
Brackets that I made to adapt the stock fuel rails to the Eddy:
6061 elbow, throttle body and new T stat and housing:
90mm MAF and NOS fuel hose that goes from the hard line to the fuel rail, my stock one is getting crusty:
Carb spacer, ARP hardware, and all of the misc. plugs and fittings to run my vacuum lines:
So that's currently where Im at. My goals with this setup is to make 370-375 rwhp with the Eddy setup on the stock bottom end, and get as close to 11's as possible with the power and suspension mods. Im sure you have noticed in the pics the Teksid block, crank, rods and pistons. That is the next stage of my build that will happen in a year or two. I am going to build a .020" over Teksid, that crank is a stock cast piece out of a '97 GT that has been polished, and the rods are stock (I have a set of ARP 2000 bolts for them) out of the same '97 engine. The pistons are .020" over Sealed Power hyper pieces. Im going to build that motor to basically drop 70lbs off the front of the car, and those pistons along with decking the block will put my compression right around 11.75:1, which the cams and intake will love. With that setup I want to see how close to 400rwhp I can make with stock cast NPI internals and higher compression on a budget. The final build will be a big bore Teksid stroker, 12:1 compression, and some monster cams, but that will be way down the line:
Teksid block:
Polished NPI cast crank:
Cast NPI rods with ARP 2000 bolts, and .020" hyper pistons with stock NPI dish size:
Thanks for checking out the thread, and Ill keep it updated as I go!
chris91
Cincinnati, OH
Looks like you're havin fun! LOL Keep this updated man, definitely love following NA 2V builds. One day when my car grows up it'll get some serious mods. Heh
03DSGGT
03DSGGT
Akron, Ohio
Im hoping that I can do some work on it in the near future. Its been close to single digits here for the past week, which has kept me out of the garage and forced to just collect parts...
Barner1
Tennessee
Man I have always loved this car! The blue valve covers look great! I know it's going to get better this winter, can't wait to see the progress!
Burninriverdiver
I hear you on that! I've been inside and with all the free time I ended up biting the bullit on pi cams and intake. This Akron Ohio weather has been brutal. Good luck on the build and I'll be looking forward to seeing the progress man
03DSGGT
03DSGGT
Akron, Ohio
What do you plan to do with the Bullitt Intake stuff?
Ive had it up for sale on a few forums, but all Ive had is low ballers. Ive got over a grand into the setup and Ive got people offering me like $600 shipped for it, so I think Im just going to put it on the shelf and save it for a future build...
03DSGGT
03DSGGT
Akron, Ohio
You will like the extra power from the intake and cams. I did a PI intake and my old stock PI cams in my buddy's Tangerine 96 vert and even with no tune and stock 3.27s he can put it to the wood from a stop and get the car sideways with an auto...it really woke the car up...
Burninriverdiver
Man I'm excited enough to start this swap, thanks for making me more antsy to get in my frozen garage! I think tomorrow will be warmer at least. What part of Akron are u from?
03DSGGT
03DSGGT
Akron, Ohio
Yea I heard that its going to get up to 30...that's a heat wave compared to what we've had..lol I'm from Munroe Falls, which is the next town north of Tallmadge...I'm like 10 minutes from Summit Racing..
Burninriverdiver
I got ya, I work in stow but live in west Akron (valley area). When it warms up I'd love to see this beast. Gotta love having close access to summit racing
03DSGGT
03DSGGT
Akron, Ohio
Oh OK, so working in Stow you know right where Im at then. And yea, we should definitely get the cars together in the spring. A couple of my Mustang buddies got out of the game, so Im pretty much on my own as far as going to shows and cruising. I have a drag racing buddy with a '68 Chevelle, but its not a street car and my uncle has a '69 Shelby, but he only brings it out if there is no rain in the forecast for like 3 weeks...lol. Im trying to get a couple of the Ohio boys from here to get together to go to the Mustang show at Summit in July so I can put some faces with the names...and living so close to Summit is a huge double edged sword...lol
Burninriverdiver
Getting some locals together for the summit show sounds like a good plan to me! And yes living so close is a double edged sword for sure man, there's been a few times boredom gets the best of me and I end up there spending more $
Tony
ohio
always admire and respect you guys that go knee deep in to motor builds. strange little thing i noticed is those center caps on the bullitts....those are fn awesome lol. what are those?
03DSGGT
03DSGGT
Akron, Ohio
Those are old school caps from Mooneyes. I work at a hot rod shop and stumbled across them in one of our catalogs. They are a hollow cone with a threaded bung in the middle, so all I had to do was fab up some retaining plates to hold them in the wheel and they worked great. Pretty cheap too:
http://www.mooneyesusa.com/Chromed-Bullet-Wheel-Cover-Caps-p/aa5.htm
Pictures aren't working... looks like you may have moved the album/file path.
peasant99
