doing a 351w swap in my 94 so I'm gonna be selling all my 302 parts. here my list. once i have the 351w in i will post prices. it is still in my car so you can hear it run if you want too.
Typhoon intake manifold upper and lower, satin finish
GT40P heads with thumper springs. good for .580" lift, come with arp head bolts.
310Ci short block. 90 block bore .060 over. dss flat top forged pistons. stock crank and rods. arp main and rod bolts. clevite bearing. melling hi vol oil pump with arp oil shaft, motor has just over a 1000 miles on it. never took it pass 3500rpms. ran only rotella oil 15w40. good strong motor. i will probably keep the oil pan on unless someone wants it. and it also has a fel pro 1pc oil pan gasket.
FRPP hydraulic roller lifters.
BBK long tube headers (fox body style, clear p style heads)
Comp double roller timing chain.
pretty much a whole engine beside the cam. my buddy is buying it from me. i used the FRPP gasket kit beside the 1 pc oil pan gasket.
then i also have some extra 5.0 parts too
Bassani shortly 94-95 headers
GT40 (explorer) intake with elbow and throttle body
