345/40/17 Toyo Tqs work on my car?
ProchargedGT
Wheelwright, KY
I got a 94-98 rearend in my 99 GT. Which causes the wheels to set in a little bit, My question is will the 345/40/17 Toyo Tqs tuck well in my fenders? I got stock springs heated for lowering, which im getting rid of soon. Especially if my new toyos do not tuck nice.. If they don't, What springs should I buy to lower my car? I'm thinking bout just getting more stock springs, and cutting half a coil at a time til the stance is perfect.
P
ProchargedGT
Wheelwright, KY
10.5 fr500s. Don't feel like buying some Streetlites yet. lol
As of now I got some 295/35/18s right now and it sticks about a inch and a half inside the wheel lip on these heated springs and it is lowered about 2-2.5 inches all the way around
det_riot
Dearborn
sooo you're going for this look?
det_riot
Dearborn
lol okay. Reason why you're using a bigger tire instead of a taller tire and a smaller wheel?
justinschmidt1
345/40s are taller....they are a 28 inch tall tire....
If you have a 94-98 rear end and the normal offset 17x10.5s it really shouldnt stick out at all from the fenders IMO.
It may rub inside forcing you to run a spacer.
I just beat the hell out of my inner fender with a hammer to fit 335s lol
P
ProchargedGT
Wheelwright, KY
I'll get a spacer if needed. Reason I'm wanting to use a bigger tire on a 17 is cause they don't make fr500s in 15s or 16s.. I don't think atleast, lol. I'm trying to do the budget way out of it..
i think you're wasting your time with a 345 on a 10.5" wheel, the proper size tire on that wheel will probably give you better traction. And if you add a spacer it's definitely going to stick out.
Musturd
Yea just run a drag radial like Mickey Thompson or some shit
P
ProchargedGT
Wheelwright, KY
Well. I NEED a 28" tire. I have a 4.30 gear in my car. I already bought these tires, and its not like if I really need to I could buy a set of streetlites.
P
ProchargedGT
Wheelwright, KY
I'll have to set it on the ground again as im undergoing a trans swap. i should of snapped some but i wasnt thinking. it fills the wheel wells nice
Suprasuavy
