For Sale 95 Vert
ivan12
Putting my vert up for sale, we're starting to look at purchasing a house and could use the extra cash in my pocket, plus I don't drive it as much as I'd like. I have a pretty long history with this car but I've come to terms with letting it go for the right price. I've had this car for almost 9 years, and before that my cousin owned it for about 3. Although the miles on the chassis are high (around 165k) most of the car parts only have about 3k. I will include extra parts that are not currently installed as well to sweeten the deal. Car is a clean titled/registered under my name (until Feb. 2015) 95 GT Convertible, color is dark tourmaline aka dark forrest green with black interior. Black carpet is in great shape looks almost new, black vinyl top is also in great shape minus the rear glass that has some separation. Car was tuned by Bob Kurgan with an SCT chip and is 99% spot on, car will sometimes turn off when coming to a stop which Bob attributed to the fact that my Speedcal wasn't hooked up but I'm not 100% sure if that's why. Car dynoed at 478rwhp and 418 rwtq. Car was re-sprayed the original color about 2-3 years ago by my wife's cousin, paint job is ok but not showroom condition although much better than a MAACO job, I might get it wet sanded and buffed if I have the time in the next week or two though which I think will help a lot. No heat or A/C with smog pump bypassed. Now to the good part, below I'll add the list of all the goodies starting with the newer parts which have 2-3k miles. Adding prices to what the stuff cost new. I'm asking $10k, no trades cash only, local sale in San Diego, Ca. If you guys think my price is crazy please let me know, feedback is appreciated. I also would gladly take suggestions of where else to post this where I don't need a minimum amount of posts other than Craigslist or eBay (want to keep it local)
Front Suspension:
Team Z K Member Package (k-member, a-arms, coilover kit, springs) $750
Strange 10 way adjustable struts (fox length) $120
Team Z bump steer kit $125
Maximum Motorsports black caster/camber plates $210
Termi Cobra remaned rack
Prothane offset rack bushings
Cobra front brake conversion (red) with 13" Baer blank discs and MM steel braided lines $600
Cobra master cylinder $100
Rear Suspension
Maximum Motorsports HD adjustable lower control arms (height adjustment) $379
Team Z non adjustable upper control arms $120
Eibach lowering springs
Shitty KYB shocks
Procharger D1SC with 3 row intercooler
50# Bosch injectors
Pro M Maf calibrated
New 302 stock block with 91' fox rotating assembly (forged pistons)
ARP studs and bolts through out bottom end
ARP oil pump shaft
High flow oil pump
Trickflow Stage 1 Cam
Trickflow top end package (HCI) 360 HP with track heat upper/lower $2800
Trickflow elbow $100
Professional Products 70mm polished throttle body
Powerbond Harmonic Balancer $150
Steeda Tri-ax shifter $150
Stock 8.8 rear with 3:73 gears
Stock tranny and clutch (more on that below)
Maximum Motorsports Quadrant, firewall adjuster, and clutch cable $139
Exhaust (bought used minus mid pipe)
JBA smog legal unequal length headers
Bassani Catted X pipe (bought new about 5k miles)
Borla side exhaust
Exterior Mods
Kaenen S281 spoiler
Cervinis Cowl hood
ABCexclusive side exhaust covers (need repainting)
Clear headlights
Vertical tail lights
Speedster cover
Shaved emblems and antenna
Interior
Autometer Nexus gauges. Oil, water temp, boost, wideband, and fuel pressure $900
Autometer dual gauge bezel $80
Termi black and gray leather seats
Double Din touchscreen conversion
Kenwood amp
FR500 steering wheel $250 (about $500 now if you can find one)
Misc. Items
Die-Hard platinum battery $220
Steeda battery box kit in trunk
Livewires and screaming demon coil
MSD digital 6 box
Wire tuck
Powder coated S/C tubing, pulleys, and Accessories
Polished S/C
Lokar dipstick
Polished overflow tank and UPR oil catch can
Mishimoto radiator with revised brackets
Ford Racing water pump
18X10 and 18X9 polished aluminum Saleen replica wheels with authentic Saleen covers
Near new rear Khumo tires
Authentic Saleen speedster cover painted when car was re-sprayed
Speedcal to calibrate for gears
Remaned Distributor
MSD cap and rotor
Canton billet thermostat housing $105
Extra parts to be installed/replaced with these:
TKO 600 Transmission with proper bell housing
Brembo 4 Piston Brake calipers with pads
Mach 1 chin spoiler
Wiper Cowl (current has 2 cracks)
Black passenger side airbag (current was tan and painted)
Classic Design Concepts styling bar with LED in mint shape
Also have a Centerforce dual friction clutch and pressure plate that I got with the tranny but not sure if it will fit since it was taken off a 96-98 4.6 as well as an aluminum drive shaft
BBK/Edelbrock polished TB
Sun visors
Spare parts if you want them
Moates quarterhorse chip for engine tuning $159
94-95 Mac Pro chamber mid pipe
Extra Borla side exhaust
Extra styling bar in not so perfect shape
8-rib higher boost pulley
TKO bell housing for 4.6 engine
Nice quality thick car cover (not the wal-mart stuff) $250
Car needs:
Buff/wax
Alignment
Front tires although not bald
Speedcal installed right
Hood bumps/adjusters or pins
Door key, lost it during tuning session
ElrodKTPQ_89
Crossett, AR
Awesome car man good luck selling it! Just curious though where did you get that water neck? I've never seen one like that before.
ivan12
ivan12
Thanks, the water neck is from canton, was around $100 new.
Carolinastang78
