96-98 SVT Cobra Suspension Set Up's
robb15033
Northern Va.
COBRA owners:
I have performed a suspension job on the V6 already using C/C plates,X2 Balljoints, Bumpsteer Kit, Springs, & Shocks/Struts.
The Cobra is a convertible & completely stock right now.
-I am ordering the X2 balljoints again. MM C/C Plates again, MM Bumpsteer Kit again.
-What springs, in your opinion now that your car is complete, would provide the best comfort ride? I am again going for at least a 2" drop. * I wanted to get Maximum Motorsports springs but do not know what the final result looks like. http://www.maximummotorsports.com/s...ct_info&cPath=514_22_323_329&products_id=1095
-Of course I have spent hours looking at our picture data base but would like to hear about comfort AND stance.
Thanks again, -Robb
imo the H&R SS give the best stance and with the right struts it rides well also. I don't believe there is any name brand spring that's going to drop the car more than 2".
Musturd
Yea like he said I doubt any out of the box springs will give you more then a 2" drop. With that being said you can't go wrong with H&R
1997GT4.6
SR springs or the sve, can't recall which of the two, promise a 2" drop.
Id go with H&R and no ISOs front or back. Trust me it will be low. I have one iso removed up front and can barely fit a finger in between. I should have removed them in the rear but i ran out of electrical tape lol. I'm gonna have to tear it apart again, i really want to be that low!
Musturd
Yea atleast the rears take like 10 mins to get out
Magic
Some time zone
Do it once and do it right. Spend the extra money and get a common name brand spring and a good strut/shock combo.
Springs:
H&R
Eibach
Struts/Shocks:
Bilstein HD (from MM)
Koni STR.T
Eibach Pro Dampers
Tokico
330CubeGt
I run stock cut v6 rear springs and 14/175 front coil overs :confused:
Musturd
Stock cut v6 or springs is for kill weight transfer
robb15033
robb15033
Northern Va.
H&R SS is what I'm going to get then, thanks alot. I appreciate that.
My parts list will be: MM C/C plates, MM bumpsteer kit, Steeda X2 balljoints, Koni STR T shocks/struts, H&R SS springs.
*If you remember, the suspension job I did on the V6 was with Fox Body parts (lowering springs, shocks/struts). Now, with the Cobra, I was planning on just purchasing 94-04 parts. Make sense??
Suprasuavy
