A little update on my new project car.
shaunk
Got the engine and trans taken out of the new stang. I also scrubbed down the engine bay.
Any body need a 3.8 and an auto trans? Both worked well.
shaunk
It's getting a 347 and a five speed is the plan at the moment. Should be a runner. I'm adding my old nitrous kit from the red car to it also just for an added kick.
shaunk
It should be, 10.5.1 compression, Vic jr heads,custoom cam, 1 3/4 long tubes,vic jr intake,750 double pumper,speed pro pistons,eagle rods,scat forged crankshaft, I also picked up a set of shaft mount rockers. I'm thinking 4.30 gears,31 spline mosers,and a spool. Going to weld up and reinforce the torque boxes when I go to swap out the rear and por the underside of the car.
94Pro-5.0
Little Elm, TX
nice, looks clean! and that set-up should haul ass. your not going with a t5 are you :mikec:
shaunk
The pink cavy is my fiance's old car. Just waiting to be picked up by the new owner. Yea actually I am planning to use a t-5. I have an astro t-5 in the garage but it's from a fox. I need some parts from an sn95 trans to convert it.
mcaligiuri
nice im doing a 5 speed swap to my v6 as well. the rear end needs to have the brake line moved to line up with the brake lines on the 8.8 rear. good luck
JohnnyOctane
