Best way to get lower?
KidK9
Cincinnati, Ohio
What's the best way for me to get lower? I have eibach sport lines all around but I still have a good 2.5" from top of tire to top of fender.
JRad405
Central NJ
Taking out the iso's could get a 1/2 in drop possibly. I think drop spindles or someone else can correct me because I can't recall but there were Steeda X2 balljoints or some other thing Steeda sells that drop you 1/2" also.
I thought Eibach's drop you a lot. When did you put this stuff in?
Slykin
Tyler, Texas
Unless you mean the inside of the fender.. you shouldn't have near 2.5 inches of gap with eibach sportlines.
for the back you can install adjustable lower control arms but yea I thought sportlines were supposed to be really low.
96TANGERINEGT
i always thaught adjustable rear control arms just changed pinion angle ?
someone chime in on this please , i am woundering now ......
will it drop the car any more ?
KidK9
KidK9
Cincinnati, Ohio
Well it was sold to me with Eibachs. Maybe they aren't truly in there. I have about 2.5" from the top of the tire to the paint of the fender. Shoot...now I'm wondering if I should get coil overs up front and then re-buy Sportlines for the rear.
No the adjustable lowers will allow you to adjust the height an inch er two.
det_riot
Dearborn
no there are different types of adjustable control arms. Control arms with adjustable spring perches for height. and Adjustable control arms with the like heim or w/e its called ends and yes those are for control arms.
det_riot
Dearborn
and imo, best way to get low low is coilovers in the front, h&r ss in the back. if its not low enough, cut a coil
JRad405
Central NJ
That's what I thought but I didn't want to say anything because I have never used eibach sportlines.
Give 3 fat chicks a ride.
Lol
OP: Do you know if they are sportlines or you were just told that when you bought the car.
justinschmidt1
What color are the springs?
Red = sportlines, black= pro kit
you dont have sportlines....
I have sportlines with no isos and can barely fit 2 fingers in my fender gap up front
X2 ball joints without the spring spacer will lower the car as will removing the isos. Figure out what springs you have first to see if its even sitting right, then go from there.
peasant99
