best way to get rear iso's out?
dutch
Is there a quicker way to take the rear iso's out, without dropping the axle etc?
the spring insolators?
you dont have to drop the rear end, unbolt the arm and thats it.
dutch
sweet, wanna drop the rear a little more. Would it hurt to take both upper and lower out?
cntchds
They are mainly for NVH dampening. If you pull the top one, you might hear a few more bumps.
bryand
i took them all out, looks great but i have second thoughts when i drive it and can hear the springs rub metal on metal when the driving gets rough
dutch
so best to just remove the bottom one? tape it up with ductape?
bryand
pull them all, just turn the radio up when you drive, its like ur girl nagging!
venom
I have mine out as well. Solution is to get a louder exhaust .
bryand
louder exhaust is a better idea than mine about turning up the radio, i feel so dumb........
dutch
I just bought a quieter exhaust.
badass98svt
You don;t need to pulla ny bolts on the arms either. Just unbolt the lower end of the quad and reg shock. then, get a long pipe (jack handle maybe) and pry one side of the reaend down. The spring will pretty much fall right out. I've done it nearly a dozen times.
gearhead
I just removed both upper and lower iso's on mine. I did it by removing the bottom shock bolt and I didn't even have to pry down on the axle. I already have my quadshocks off, so that made it that much easier.
Suprasuavy
