Brake bleeding
apsmith49921
So I put new stainless lines and ats brembos on the car. I cannot get the pedal to feel correct. I have bled all the calipers and go no bubbles but the pedal is still total garbage.
One thing to note. When I changed the front brakes I let the reservoir run dry on accident so the front lines emptied completely
cobrajeff96
Germany
You need to make sure that the calipers are fully bled, and by that I mean both bleeder screws on each caliper. You now have two per side. And so the correct bleeding sequence will be:
Passenger rear
Driver rear
Passenger front (inside / outside / inside)
Driver front (inside / outside / inside)
You will go through a bit more fluid now because of the extra bleed steps and the overall larger volume of the front calipers. Do it the old fashioned way, the two-person method. It's tried and true and will never fail as long as the master cylinder has fluid above its drain and you don't accidentally release the brake pedal with a bleeder screw still open. Don't use old fluid, even if it's the newish fluid that you just ran through the system. Needs to be brand new from unopened bottles.
if you got air into the lines before the abs pump, the pump needs to be cycled to get the air through it and bleed it. There are computers that can do it for you or when I put my baers on I didn't have the computer so I found a dirty parking lot and got it up to speed, then jumped as hard as I could on the brakes to get the abs pump to cycle and work the air through it. After that I was able to use the power bleeder to get the rest out.
cobrajeff96
Germany
I've never had that issue, myself. When key is off, ABS module should be wide open. I wouldn't think you'd need to cycle it, should just bleed without any special considerations. The later models S197+ I've heard are different and usually require the external computer.
On the subject, you may need to bleed the master cylinder if air was allowed to get below the fluid reservoir, it should have bleeder screws on the side of it. OEM m/c that is.
apsmith49921
apsmith49921
I tried bleeding the master. I didn't get much air out of it. Bleed both screws on it as well
yes if you get air into the abs pump it takes a little bit of work to get it out. I had the same problem when I did my swap and changed the MC.
J_lope82
South Texas
I just bled mine yesterday because I replaced the hydroboost. I did it the old school way with two people. You said you ran the master cylinder dry. Don’t let it run dry or you will need to start all over. Check it after you bleed each caliper to make sure it’s not dry.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
The guys at wilwood told me, the easiest way is to have 3 people. Take the lid off the master, crack a front and rear bleeder, then have a 3rd person push the pedal all the way down nice and slow. That will move the most fluid. Then tighten the bleeders, release the pedal, and do it again. Make sure the master stays full.
apsmith49921
apsmith49921
I should have clarified I ran the master dry when I installed the new lines not last night when attempting to bleed them
oz95gt
Bathurst NSW Australia
If you're car is a GT you might need a Cobra master cylinder to account for the extra pistons , remember reading years ago about GT to Cobra rotor and caliper swap you would have a soft/doughy pedal with the GT master cylinder
lwarrior1016
South Mississippi
gt master cylinder works just fine with cobra brakes. The Ats brakes may require a different master for optimal pedal feel, but shouldn’t be a problem for bleeding.
96blak54
In the shop
100 % make sure the reservoir stays full! I found myself making circles to all 4 corners bleeding each brake once and move to the next brake untill no air in the lines. This took awhile.
cobrajeff96
Germany
I was gonna say having two bleeders open might drain that m/c quicker than you can check it.
apsmith49921
apsmith49921
It's a cobra so master shouldn't be an issue. Would it be helpful to have a real vacuum bleeder? The big one from like HF or something
that is the one I used. You will still probably need to cycle the abs pump after you bleed them, and then bleed them again after it is cycled. Like I said I just found a dirty parking lot and you just have to get the abs to kick in and it will work the air out into the lines where you can then bleed it.
apsmith49921
apsmith49921
I'll try the bleeder and see where I get. I've got rather large gravel driveway so I'll get the abs to kick on after if thise doesn't work
Suprasuavy
