brake Pad only grabbing outside of rotor?
justinschmidt1
Just put a new caliper on and it seems like the pad is only grabbing the outside of the rotor...
If I look at the rotor I can see 1/2-3/4 of an inch rusted ring where the pad is not grabbing.
Any idea what would cause this to happen?
NERD
Virginia
Air in the lines & of course a faulty caliper. Try bleeding it again and see it helps out.
J
justinschmidt1
Ive bled these things like 3 times...
these calipers are garbage man...
one was permanently locked up.
now this one is like cockeyed...wtf
MustangChris
Aurora, CO
i was going to say maybe one is locked up. I had the same problem on my V6's caliper back in the day.
Win
Kennesaw, Ga
98gt said:
have you checked the sliders?
+1 Check the slide pins. I always put a healthy coating of antiseize on them when i do a set of brakes. You might also have to reload the calipers and get a rebuild kit.
J
justinschmidt1
Its a brand new caliper.
2slo95fiveoh
Lawrence, Kansas
It's junk then.. If you have properly bled them, and they are not touching on the inside, then the caliper is not extending out of its bore.
If anything, your inside pad should wear slightly more than your outside, but it sounds like you have a bad caliper. These were 100% new, not reman?
J
justinschmidt1
Its not wearing only the inside or outside pad...
if you were to look at my rotor from the outside if the car, half the rotor is orange like only half of the outer pad is touching the rotor.
and its a reman PBR unit
2slo95fiveoh
Lawrence, Kansas
ok... I would take your caliper off the anchor, make sure your caliper slides are well lubricated (as well as the portion of the anchor where
the pads rest), then depress the caliper piston all the way in. I'm not doubting your install, but I've seen improperly installed brake pads
only touching the rotor in a 1/2" space or so.. If it goes too long it can build up excessive heat and cause the rotor to warp.
J
justinschmidt1
Im gonna pull it off and take a look at it.
The pad has to be in the right spot for it to even work and ive done brakes many of times.
Win
Kennesaw, Ga
Just because it's a brand new REMAN caliper doesn't mean the slide pins weren't lubed properly.
also being a reman could also mean it wasn't rebuilt properly by the company that did it. It sounds like the caliper itself needs to be rebuilt again. I personally would take it back to where i got it and get it switched out.
Win
Kennesaw, Ga
OnyxCobra said:
i mean did you maybe put the pad that was on the outside on the inside and vice versa?
Unless he had the pads already seated, then took it all apart and accidentally switched sides then maybe. But normally you can just take out a pad and slap it in the caliper.
NERD
Virginia
My 03 was doing the same thing. I just upgraded to Cobra brakes. (Well actually they're still in the box waiting to PC'ing.)
J
justinschmidt1
weird...it doesnt even make sense for it to do that.
I cant understand how its even possible for there to be uneven pressure on that side of the pad.
NERD
Virginia
Me either. Wait for it to start locking up while you're driving, lol.
Suprasuavy
