Nightmare
I dont know why he even has camber castor plates if his suspension is stock. there is a possiblility that the plates/strut assembly is not assembled propperly as well. I would start by drilling that extra hole.
I think the PO may have had lowering springs on the car at some point. I'm not sure why they're on the car. I replaced the front struts a couple weeks ago and I think I might have not put the adjuster bolts on the struts back on in the proper alignment. I'm not sure if the guy doing the alignment even checked those thinking the plates were all he needed to adjust.
Would having those out of whack be enough to keep it from being aligned even with the plates? I saw somewhere that those only give you like a 1 degree either way, don't the plates have enough adjustment that they'd still be able to straighten it back out?
