Cobra Front Brakes
94Pro-5.0
Little Elm, TX
I'm about to buy some cobra front brakes. My stock pads and rotors are pretty worn out so I want to just replace them with the Cobra set-up. I have a couple of questions.
besides the caliper brackets, calipers, rotors and lines, is there ANYTHING else I would need?
My buddy has a 91 GT. If he got the right spindles, could he put my stock brakes on his car?
SRT Handz
Unless your doing the Rear also, you dont need caliper Brackets.
For the front you need....
-Calipers
-Lines
-Rotors
To do the Rear all you need it.
-Rotors
-Brackets
V6/Cobra/GT all use the same Rear caliper
....and i think 94/95 cars require a master cylinder swap but i am not sure.
Spd0lit
SoCal
The master cylinder is not necessary the only side effect is a really firm pedal and to me that is a plus.
94Pro-5.0
94Pro-5.0
Little Elm, TX
ok, well i'm about to buy only the front calipers from a guy less than an hour away.
so, all i need to order are the small lines (stanless ones from MM work?)
and rotors and i'm set?
sounds too easy
These are THE ones i'm going to pick up on friday
what are these worth?
Spd0lit
SoCal
Yup its that easy. Looks like you will need some pads too. But those look new, so 150-250 is reasonable if not more. Yup just need lines(MM), pads?, and some brembo blanks will set you up.
94Pro-5.0
94Pro-5.0
Little Elm, TX
thanks guys
will stock style pads work with the cobra calipers?
i already have a box of new pads so that would be sweet
oh, and i'm getting them WAY cheaper than 250 :coolsmiley:
Spd0lit
SoCal
you will need pads that are specific to a cobra or that caliper. The two holes on both sides are where the pads "clip" into place.
96sohc
I don't use anything other than Brembo blanks.
No slotting, no drilling, no nothing.
94Pro-5.0
94Pro-5.0
Little Elm, TX
thanks for the link handz. they emailed me back with some great prices. i'm pretty sure they are who i'm going with :thumb:
SRT Handz
tell them you saw a group buy on Stangnet and they will knock more money off
Goindeafonmtx
sounds too easy
Wheres the mounting brackets?
94Pro-5.0
94Pro-5.0
Little Elm, TX
i have been told i could use mine on my car :dunno:
the guy selling those calipers wont answer my calls :tickedoff:
hopefully he will soon, i want them
when i order rotors i'm going to get the dimpled/slotted. they look killer
Carolinastang78
Staff online
