endlinks
white95
Apex Junky
Prairieville, LA
Finally started putting my front sway bar on and naturally, the endlinks were too long. I can just go buy a shorter grade 8 bolt and make it myself. Who would have such in stock??
white95
white95
Apex Junky
Prairieville, LA
thats what I was thinking, but do I have to take a measurement or is there a standard smaller size?
MustangChris
Aurora, CO
they have OEM size for reuglar suspension
and shorter ones for cars lowered more than 1.5"s
white95
white95
Apex Junky
Prairieville, LA
sounds good to me, i'll continue with energy suspension though... I have their sway bar, motor and trans mounts already...
MustangChris
Aurora, CO
yea, stick with what youve started with energy suspension makes good stuff too.
wytstang
You only need shorter one if you are lowered 1.5 or more right? I'm pretty sure my steeda springs didn't drop me 1.5'' but it would suck to get started only to have to stop and find a smaller bolts.
white95
white95
Apex Junky
Prairieville, LA
2" springs and the QA1 kmember dropped it at least .75"
Blind
the stock ones will bolt up no matter the drop, but the sway bar will no longer sit at the correct angle (level to the ti-rods + control arms) so you will get bump steer without the shorter endlinks.
white95
white95
Apex Junky
Prairieville, LA
Yes, they would've bolted up but I decided I didn't kike the severe angle of the bar
wytstang
So I might as well order the shorter end links? I run Steeda Superlite springs with prothane ISO's,drops about 1-1/8" to 1-3/8"
white95
white95
Apex Junky
Prairieville, LA
WOW!! Talk about a great mod!! Poly endlinks and poly sway bar bushings dramatically tightened up handling.
wytstang
Blind said:
does your swaybar sit level?
Haven't tried to install it yet, been raining the past couple of days. I just don't want to get started and then have to put the stock stuff back in. I try to have everything ready before I get to it. Guess I'll just "bite the bullet" and see what I get before ordering anything else.
SRT Handz
I got my shorter ones from Stangsuspension but MM has them also
Carolinastang78
