Help needed please !!!!
Forsakendreamerz
Yesterday I started my 96 v6 and it died but started right back up but I noticed wen I put it in drive the oil pressure and battery gauge jumps any idea why ?
b1pig
Without any further info, I doubt anyone can give you a good option.
First couple of guesses.
1- make sure your ignition key is "centered" back in the "run" position after startup.
2- what is your battery voltage before starting?
3- is the alternator charging?
All gauges are electrical. If multiple gauges are affected by a problem, then it will be electrically related.
Battery. Alternator. Harness connections. Ground wires and grounding straps from engine to body, body to battery and battery to engine.
Good luck.
r3dn3ck
If it were a chebby then that would just be how they often work. Since it's a ford... gremlins.
rlmobile636
