How To Build Low-Budget Car Ramps
If your car is too low that you can't fit a jack anymore, it might be time to invest in some car ramps.
I made these with basic tools and about $20 worth of supplies.
Things you'll need:
- 1x8x12 wood plank (x2) - $14
- Pack of 2" or larger screws - $7
- Drill
- Drill bits (5/32)
- Phillips drill attachment
- Phillips screwdriver
Template:
Step 1:
Cut pieces into appropriate sizes as listed above. You should have 2 of each size. (4', 3', 2', and 1')
Step 2:
Start by placing the 3' plank on the 4' one. Mark and make pilot holes using the drill. I used a 5/35 bit for this.
Make sure the holes are spread out evenly. You should make the holes towards the ends of the plank.
Step 3:
Insert the screw into the guide holes. Make sure to tighten them down by hand with a phillips screwdriver.
Step 4:
Repeat step 3 with remaining 2 planks. Make a staircase design. Once you are done with each level remember to tighten all the screws down by hand.
For reference I used a minimum of 8 (4 on each end) screws per level.
At this point you have finished building the ramps.
They should give you about 6" of extra clearance.
You can now go ahead and try them out.
I only had to drive up to the second plank to have enough clearance for my jack.
And if you're wondering, the answer is yes, they will fit in your trunk. :thumbsup:
Disclaimer:
- feel free to add another section atop the last plank to stop the car from going too far and sliding off. A simple 1.5" high piece of wood will suffice.
- add another block of wood behind the tire to act as a tire stop.
- angle the planks at the end to make driving up them a little easier.
the5.ohh
Shaolin, NY
Damn thats pretty cool lol. I had to get spare pieces of wood and stack em to get my car up. After i put the chin on I wasn't able to just drive up on my normal ramps. I'll have to try this sometime as it would really come in handy. How much did it all cost when said and done?--> Never mind my last sentence, just read your O.P fully lol.
Jnicho
I'm going to have to do something like this. Since I lowered the car I can barely get over a penny...let alone up normal ramps.
Orange 94
Alberta Canada
Thank you. I should get around to building these. The mustang and the Mazda are both too low for my jacks.
ProKiller
PA
i would tweak this slightly to add another piece going vertically on the back so that you have a stop point once you reach the top. otherwise you're liable to drive right off the end.
CC'S95GT
Hampton ,Ga.
I was just going to suggest this very thing. Also another block you can place behind the tire to keep it from rolling off.
Good point gents'! I added those to the end of the write up. Thank you.
nice job, I've wanted to make some of these for a while now but somehow i never get around to it. I like how they fit in the trunk, that's convenient.
95opal
one more suggestion. take your 8' wack in half... stack em together... pull 12" on each end to make your top pad...snap a line from those two points. cut your line done. screw it together
Jnicho
Would it be a benefit to cut the ends you drive up/over on a 45?
95opal
hence why I suggested to just snap the line. don't know if it would be a 45 didn't do the math on it but it would be a true straight angle all the way up. Do the math and you can figure the length youll need to get the desired angle you want. I would think a 30* would be a bit easier of a climb
do you have any rubber on the bottom? I would be afraid of pushing them if there wasn't any but good idea. I just hit the "+" button myself
air ride FTW :headbang:
Some people will say yes but honestly the car made it up with such ease without having the ends angled. It's up to you.
CC'S95GT
Hampton ,Ga.
I have something similar in my garage to get up on my metal ramps which are about 9" high.
My ends are squares off and the car has never had an issue going up the 1 1/2" thick 2x8.
g36 monkey
Orlando, Fl
Mine are a bit longer to make room to clear slammed cars the whole way up. The edges are beveled and they have a stop on the front of them. I'll be using them in just a minute actually haha.
Good write up ferocious
krazyrabbit
Richmond, VA
Nice! Thanks for the write up and comments, will be a winter project for me and my Dad when he visits.
J-rod17
Nice write up.
I actually followed the ones on MW when we did mine a couple months back. Mine are NOT movable in the trunk though. lol.
Work well for oil changes and such
photo.php
RevJon
