How to measure to know if my rims will work with this upgrade?
maillemaker
This looks like a pretty easy upgrade.
How can I measure my rims to know if they will work with it?
well the only way to know for sure is to install them and then the wheel, but knowing the size of the wheel and the offset might help
badass98svt
Hmmm, those LOOK like they would have enough clearance behind the spokes.
This thread should help you out a bit.
95opal
I always use a straight edge and tape measure.
This guide will help you get all measurements you need to know.
Mustang5L5
Going to depend highly on the shape of the spokes, vs strictly by offset numbers.
1998 Cobra wheels clear by a mile and those are 17x8 +30. However, the same 17x8 +30 Bullitt wheels will not clear at all without a lot of spacers. Same wheel specs, but it comes down to wheel design.
My 18x9 Cosmis XT-005R's +35 did not clear without a spacer.
A template would really help. I almost made one when i was knee-deep in that above linked thread.
EDIT: something like this
95opal
This is why you measure brake protrusion. The link i provided gives you every needed measurement to verify fit. Its not rocket science. Proper measurements and youll know within minutes.
Mustang5L5
But OP doesn't have the calipers installed, so really can't measure directly. He would need someone to do it for him and give him dimensions to check against his rims
rlmobile636
