Lower control arms worth it?
x182dan
SRT Handz said:
Chris, MM techs say that spherical on both sides on a street car is just too noisy and they advised me against it.
I took the advise and am 100% satisfied
I basically got the same answer when I talked to the tech
SRT Handz
Hey justin, if you buys Any other brand LCA besides MM, GW, or Griggs, then i am gonna flame your for life and you cant be my friend anymore.....
J
justinschmidt1
Whats abouts LakeWood's?
I heardddsss deys was aight?
duff daddy
or you can man up and get some with relocatedl owers and 135% traction over stock and be a real bad ass on the strip/street.....
J
justinschmidt1
hahahaha
Justinschmidt1: Now accepting paypal donations for LCA's so he can be a real bad ass on the street/strip
Anyone?
cntchds
El_Diablo said:
global west control arms are actually a better design aside from the weight jacking feature which most people have know idea how to use
http://www.globalwest.net/1979-2004_Mustang_performance_suspension_parts.htm#Rear%20Tubular%20control%20arms
i have the tbf-1 control arms
From that link...
Global West said:
Panhard rods will not work with TBF-1's. The panhard rod will create suspension bind during travel.
What's up with that? I've never heard that before...
duff daddy
justinschmidt1 said:
hahahaha
Anyone?
250 bucks for hpm's or as they are now known as Ford Racing Lower Control Arms...if you need a link let me know
MustangChris
Aurora, CO
hahahaha
Anyone?
i do
SRT Handz
The MM arms are only $10 more.....
SRT Handz
The FRPP arms dont have a spherical on the axel side....that caused bind
MustangChris
Aurora, CO
what casued bind? not having the spherical, or having the spherical?
hell, whats a spherical?
duff daddy
YOUR opinion is that they are an infirior part to your amazing mm lca's GREAT have a cookie. MY opinion, is that with the double adjustable, relocated lower's from FRPP they are the best for what I need and want. when you cut 1.6 shor times with a stock shocks springs axles and a clutch with 125k come talk to me.
As far as spherical... all that means is when its turn, its not in a perfect circle, so you get a larger amount of adjustment out of it. Chris, most people will get that type of a bushing or the uppers in the rear to adjust their pinion angle for traction and launches (for the drag racers) and for auto x guys do it im sure for the same but i dont play on that side of the fence.
SRT Handz
Poly bushings only go Up and down.... If they twist, they cause bind.
Our axels dont move up and down, they twist when you turn so you need a spherical bushing on the Axel side to prevent bind. Look at my MM LCAs and you will notice a metal spherical bushing on the axel side...thats the key to a Good LCA.
El_Diablo
not a fan of poly..... spherical and delalum bushings FTW
im going to try with a panhard bar first and if i have bind it will be removed in favor of the watts link (which will eventually happen either way)
J
justinschmidt1
free candy bitches!
J
justinschmidt1
Candy candy candy
fuck a MM lower control arm
Just get some jb weld and some popsicle sticks and make your own
Boosted94vert
