lowering 98 gt
just a 98 gt
ok heres what i have i have the sportline lowering kit and i still have an anoying wheel gap in the front i have the 17' buillit wheels with a 245/40/17 tire on it , my question how can i lower it anymore like about 1/2 in anything tips will help thanks
SRT Handz
Take out the front spring isolators and it will look like this
SRT Handz
just a 98 gt said:
how does it ride ? and have you had any problems with it?
rides like a lowered mustang..... only problems is i scrape on everything
LI98GT
Long Island, NY
Could be that you've got slightly smaller tires on the 17x8 rims that's adding to the gap issue? Upgrade to the larger size? If I remember right, my stocker 17x8s came with 245/45 not 245/40s. I had a wheel gap on mine with the bullitt spring setup, which is much better now that I removed both upper and lower front isolators. You might want to try removing only the upper isos, which is where most of the space comes from and leaving the lower on so you don' have metal-metal contact from the arm all the way up.
Ride didn't get diminished a bit over smallish bumps, but those rare times that I hit a major pothole or bump it crashes pretty hard. I'm just extra careful when it comes to those major holes/bumps now and keep a keen eye out to avoid hitting them at almost all cost.
J
just a 98 gt
well see i had 245 45 on the front but i got the new ones for FREE!!! and i wasnt going to pass it up but i might take only the top ones out and see how it goes but thanks guys
Suprasuavy
