need to know if
ReplicaR
You can do it, but you will have to run a pretty low spring rate. HP series has pretty weak valving, so I doubt it will cope with anything over 175 coilover spring.
cntchds
The information I got from MM was basically "don't do it." They are meant for fairly low spring rates, and are really marginally better than stock dampers. I would only think about doing a coilover set up on Bilsteins, Konis, or D-Spec Tokicos(If for some reason you are completely in dire need to use Tokicos.)
But to answer your original question, yes any Tokico coil over kit will directly fit onto your HPs.
Bilsteins or konis.
other than that, wouldnt be worth buying coilovers. IMO
B
Black Ice
thanks for the input guys i will be selling the blues then
Suprasuavy
