October 2016 ROTM - Voting
Status
Not open for further replies.
Orange 94
Alberta Canada
Vote for October 2016 ROTM!
[MENTION=14844]97_281gt[/MENTION] [MENTION=17027]whiplash473[/MENTION] [MENTION=20552]Lanter[/MENTION] [MENTION=13575]9838stang[/MENTION] [MENTION=18830]Frank.JD.Perez[/MENTION]
97_281gt
97 Mustang 4v swapped, qa1 tubular front suspension, upr front coilovers, BBK long tubes' o/r h pipe, slp cat back, egr and other emission crap delete, sct tune front cobra brakes, afs cobra wheels tri ax short shifter terminator seats, s281 wing, shaved rear bumper, 00 cobra r hood
whiplash473
Forged 331 stroker blueprinted throughout
complete Trick Flow top end
rebuilt T5 w/ Pro5.0 shifter and 450lb Centerforce clutch
3.73:1
complete debadge and re-spray of factory color
Cervini Stalker wing and hood
Cobra front cover
03 Cobra wheels
AEM afr, oil psi, and water temp gauges
MM bumpsteer w/ solid rack bushings
BBk long tubes, custom X pipe, Flowmaster Super44s
under-hood fuse box area still tentative and under construction
Lanter
Engine:
0.020 Teksid
Stock micro polished cobra crank
Diamond 2618 dished pistons (-11cc)
Manley H beam rods with ARP2000 rod bolts
ARP fasteners: main studs, side bolts, crank balancer bolt, head studs
Manley stainless steel intake and exhaust valves
New valve springs
Valve job/bowl port
TSS billet oil pump
New ford timing chains/tensioners/gears
COP conversion
Underdrive pulleys
MMR IMRC delete plates
On3performance coolant crossover delete with Aeroquip braided hose and fittings
Turbo Kit:
On3performance gen 2 forward facing single turbo kit
Turbonetics hurricane 7868 benita turbo
Twin Precision PW39 wastegates
On3 50 mm blowoff valve
RPS v-bands clamps
VS racing turbo blanket
DEI Lava exhaust wrap
Drivetrain:
Close ratio tremec t56 magnum six speed
McLeod RXT dual disk clutch
McLeod flywheel from 2003 Cobra
2003 Cobra IRS with poly bushings and billetflow brace
Fuel System:
E85 fuel
Glenn's performance sumped fuel tank
-10 suction line, -08 feed line, -06 return line (all black ptfe braided stainless lines)
Stainless 100 micron pre-filter
10 mic post filter
dual 300 LPH walbro fuel pumps in parallel
Fore innovations F2i FPR
Aeromotive fuel rails run in parallel
Siemens deka 80lb injectors
Exhaust:
SLP loudmouth II IRS catback
Suspension:
UPR tubular chrome moly k member
UPR front coilovers with 250lb front springs
Hotchkis camber plates
MM bumpsteer kit
Exterior:
Aerocatch hood pins
Rear wing deleted
97-98 export tail lights
Clear amber corner lights
Interior:
Corbeau FX1-pros
Homemade RSD
MM 6pt roll bar with swing out door bars
Custom gauge/fuel pump/accessory relay panels
Battery relocated to trunk
Speedhut boost gauge
Speedhut fuel pressure gauge
AEM wideband gauge
AEM tru boost controller gauge in custom cup holder gauge pod
Wheels/Tires:
Chrome Saleen LeMan's 18x8.5 front 18x10.5 rears (widened by WeldCraft Wheels)
Sumitomo HTR Z II 245/40/18 & Toyo proxes tq 315/35/18
700 rwhp and 681 rwtq tuned by Lee Blankenship!!
9838stang
I have had my car for over 10 years now, I have done many mods to it over the years. The most recent was to Mod i had dont the car, was when i bought a roached 00 gt. The motor and tranny from the 00 was in grear shape, along with the wiring harness brake lines and some running gear. So, with the help of a buddy, he and i turned my 98 v6 auto mustang in to a 98-00 mustang with a 4.6 pi 2v manual car.
Exterior:
S281 rear replica spoiler
Clear head lights and fog lights
  • Painted headlight buckets
  • Mini Morimoto H1 6.0 Projector retrofit
  • 6K LED conversion
03 Mach 1 chin spoiler
Hash marks up front and wrap around to the rear
Stainless Steel "Mustang" rear letters
95 mustang mustang mirrors made into faux exports
Sequential tail lights
LED Reverse lights
35% tint
Interior:
Full 00' Mustang GT wire harness
00' mustang Dash frame
01 Mustang Bullitt Cluster with LED Cluster swap
96 black and tan door panels and Air bags
03 cobra parchment seats
redyed tan carpets
black floormats
Mach 460
Pioneer DEH5800 DECK
Pioneer Speakers
Bullet window switches
Suspension/ Driveline:
94 GT 8.8 w/ FRPP 3.73 Gears and Motive Install kit
T45 manual transmission Stock internals and stock clutch
SVE QUADRANT AND CABLE ADJUSTER
98 Cobra front brake conversion
BAER rear 13" rotor converison
Front Stainless Steel brake lines
Rear 94-98 cobra brake calipers
H&R SS springs with only front upper isos and new rear spring isos
Tokico HP blues
Steeda X2 Ball Joints
J&M CC plates
J&M upper and lower rear control arms
GT sway bars
1" rear wheel spacers
Shorter front swaybar links
Competition Engineering Bumpsteer kit
1.75 +/- camber bolts
Authentic Ford Racing FR500 18x9 silver with polished lip wheels
Nitto NT555 ZR Extreme 245/40/18 285/35/18
Engine:
00' Mustang GT 4.6L SOHC
75mm Trickflow TB and Plenum
K&N CAI
SCT SF4 TUNER with BAMA TUNE
99-04 GT Maganflow Catback
BBK Long tubes and BBK Catted Mid pipe
Frank.JD.Perez
Exterior
OEM cobra front bumper and fog lights
OEM style cobra front lights
carbon fiber svo side skirts
carbon fiber s281 spoiler
Ford Racing FR500 rims (275 40 18 all around and 1 in spacers in rear)
Gorilla Automotive chrome locking lug nuts
led 3rd brake light moddified with a flash rate
slow rate sequential tail lights with flat black bezels
side rocker stripe in flat black
flat black hood scoops
flat black roof
lots of stickers! (included are racing number and name with country flag and current course raced on)
Cipher Auto front and rear blue tow straps
Interior
white face gauges (speedo & hvac)
replaced gauge lights with white leds
Sony xplod stereo with bluetooth
OEM mach 460 system
10th anniversary style mystichrome cobra steering wheel
Performance parts
78mm BBK throttle body/plenum combo
Airaid ram air cai
Steeda timing adjuster at 12*
Steeda cc plates (3 bolt)
Ford Racing lowering rear c springs with isos on the rears with a coil cut
H&R super race front springs
Magnaflow tru x off road x pipe
Magnaflow 4x9 performance mufflers
offset twin 3.5 in tips with custom side exhaust piping
Ford Facing speedo re-calibrator and 327 rear end swap
13in front cobra style rotors w/bullitt twin piston calipers
Maximum Motorsports SS front brake hoses
cleaned and detailed engine bay and exhaust piping
Events Raced at and upcoming
3.12.16 SCCA Starting Line @ NASA Crows Landing (44.xxx seconds)
9.15.16 SCCA Track Night in America @ Thunder Hill Raceway West (1:47.xxx)
9.25.16 SCCA Solo Nationals @ Marines Corp Airbase El Toro (71.xxx second)
10.30.16 Streets of Willow @ Willow Springs Raceway
Pending parts for install/purchase
Maximum Motorsports full length sub frame connectors
Maximum Motorsports MM Sport Bilstein front struts
Energy Suspension Poluurethane motor mounts
Ford Racing 373s with FRPP Trac-Loc 31 spline rear differential
J_Sty_
Tampa, Fl.
Gotta vote for the homie [MENTION=14844]97_281gt[/MENTION]
97_281gt
Thanks bruh would like to win never had the chance this my first time being picked
Sent From Your Moms Phone
J_Sty_
Tampa, Fl.
I've only won once and it was a tie, Alex and I shared it and I wanna say it was actually last Oct.
97_281gt
You almost won last month pretty close
KDerekT83
All choices are amazing cars in my opinion, however I had to vote for Whiplash due to my personal partial-ness to a classic pushrod motor, and the fact that his engine bay is pure sex for me...
whiplash473
Northern IL
That means a lot, I'm an old time pushrod guy myself. Thanks. It still has a long way to go in my mind.
Sent from my bored/stroked iPhone 6S
1994Gtvert
NJ
All the cars are sweet.... You guys are really making it hard to pick.
Lanter
Indiana
This was tough but [MENTION=13575]9838stang[/MENTION] gets my vote just on how far the cars come and how clean it is!
97_281gt
Has anyone on there but me never won before?
Lanter
Indiana
Out of all the people on this site only 21 have voted?...Come on guys I don't want to win this. There's way better cars up for voting than mine
Your cars more than worthy of winning. Really done well and you actually track the car!
Status
Suprasuavy
