Ordering Caster camber plates for 98 !! HelppppHELP HELP HELP HELP
Hey guys.
Well i need to order my caster camber plates for my stang TODAY. they need to be here before friday so i can put them on.
Anyyways i bought them off Billed Depot and when i am checking out it asks me the spring rate.
Its got lots of different options like.
12-250 FrontFactory lowered car
14-175 Front Street/strip car
What its my spring ratio?
I HAVE INSTALLED BLUE TOKICO S/S AND UPR SPRINGS.
ANYBODY KNOWS?
THANK YOU . I NEED THIS BEFORE ORDERING.
:headbang:
eliyarbrough
Nocona, TX
Crap, I didn't realize you would be so technical! I was hoping to post like a 'I got FRPP ones from Summit' or a 'Look @ Stang Suspension in the Sponsors listings'. You're asking for crap way smarter than I can think of!
I do know you can ask the Stang Suspension guys! They helped me with stuff! They are super-nice guys!
94greenhunter
i bought mine off of americanmuscle.com and did not have to specify what everything was
GDawg
Find out what your front spring rate for your UPRs are. H&R Supersports are pretty stiff, 700-760 in the front. My Maximum Motorsports (Caster Camber plates) never asked for the spring rate. I'd be a little suspicious of the place that's making your CC plates.
S351Saleen
I just bought Steeda 3 bolt for one of my cars that I'm putting on now. I didn't want to drill the 4th hole...just because.
The Steeda and others have a spherical bearing up top, this is what I wanted because it's stronger. It could be used with coilovers if you ever want to. The Hotchkis and others with a bushing up top are not recommended for coilovers because now all the weight is on the bushing. If you have stock springs it doesn't matter and you can run a bushing instead of a bearing. But why not get the bearing? They cost the same.
It shouldn't matter what the spring rate is? :dontknow:
ReplicaR
Who are these "others" that you speak of?
S351Saleen
Any plates with a bushing instead of a bearing. "Saleen" CC plates had them but they were made by Hotchkis I'm pretty sure. I don't remember what ones have bushings vs bearings, off the top of my head all I could remember was Hotchkis. :dontknow:
Maximum Motorsports are bearings and I have them also on one of my cars. Since it's a S351 I didn't want to drill holes in the shock tower.
Heres what I think are the best plates Griggs Racing, I don't have them but I have a full Griggs suspension on #77 just not the plates yet. See what they have to say about 4 bolt plates.
http://www.griggsracing.com/index.php?cPath=4332_4310_4348_2005_3085
Sean 96 GT
First off you should've went Maximum Motorsports hands down. Secondly it doesn't matter what your spring rate is.
GDawg
Griggs and Maximum Motorsports are both excellent... but now it's a name calling, claim making issue.
I drilled... I bottom out... I rip into the Mustang universe... Car is still fine.
Suprasuavy
