tubbed 95
pro5.0
Hey everyone I'm new to this sight and I'm still working out the kinks but i have a question is there anyone on this site that has backhalfed a 94-98 mustang I'm in the middle of this project and need a little info. :BangHead:
Magic
Some time zone
what kinda info are you looking for? doing a full tub/back-half or mini tub??
P
pro5.0
I'm doing a full tub i have everything cut out and i have my dropped crossmember cut to length but I'm having a hard time finding out the height it needs to be at refersing the floor pan where i think it needs to go looks to low to the ground
Magic
Some time zone
I would mount the crossmember (Im assuming transmission cross member) when you have the engine and trans mocked up into the car. At the same time you can determine driveshaft length and set the correct driveshaft pinion with whatever transmission mount you are using, then weld the crossmember back up to where it should be.
P
pro5.0
No im talking about the drop crossmember for the for the back half frame rails.
Magic
Some time zone
P
pro5.0
Man thanks you are a life saver :notworthy:ive done alot of off road back halfs but not a unibody ill post some pics in a few weeks to let you see.
Carolinastang78
