After much consideration, and lots of comparison shopping, I’ve decided to go with an On3 fuel tank/hat setup. Quite similar to was
@lwarrior1016 just installed but a few exceptions.
This is an On3 03/04 Cobra style, baffled tank. This has the fuel basket in the center of the tank and it better suited for my use.
This is an On3 triple pump fuel hat and fuel level sending unit. I will configure this to run one pump and have an 8AN feed and 6AN return line. My current Holley setup will run this and it should jive with my fuel gauge. I’ll also have to switch to a 99-04 style filler neck.
This is the most cost effective (under $800) way to improve my fueling situation, leave room for growth if the need arises and with the least amount of down time.
