Have had a ton of stuff done at a local shop to get my Snake “running like it should “. All the work was completed, including 2 cats (car didn’t have any and no way it’d pass CA smog), then got dyno’d. 200hp! That’s lower than stock original without a SC. SO, they are going to do a compression check down and see what it needs.
Also, the smog pump, EGR, sensors, tubing all missing
Air/fuel is bang on; SC is at 5.7lbs boost, but car was dogging out at the 1:1 ratio on the dyno. Sounds like I’m rounding second and heading for a rebuild! Watch that 3rd base coach, see if I should stretch it out to an inside the park home run!
