1994 Mustang COBRA - speedometer not working
Meir
HI Guys,
My car is 1994 Indy Cobra (5.0/Manuel)
My problem:
My speedometer stopped working (I bought the car like that).
I bought the “Odometer Gear Repair Kit 1994-1998”, and after opening the dash, I checked the gear and everything looks just fine. No tooth was broken and nothing looks like a problem.
Then I installed new “sensor speed”. While replacing I checked the gear and it look bran new. No tooth is broken.
It’s a low mileage car. around 30,000
What should I do next? Any suggestion what to check and can be the problem.
Thanks for your help
Meir
evilcw311
Most Evil Member!
Louisville, KY
Gauge cluster can be bad. These are notorious for shoring out on the spedo.
Meir
All the gauges/lights works except the speedometer.
you would still put your suspicious in the gauge cluster?
any other idea?
evilcw311
Most Evil Member!
Louisville, KY
any other idea?
I’ve had 2 clusters go bad. Both was just the spedo
Meir
can I replace just the speed gauge or it come as a pair with the Tech RPM?
Srchop16
