1995 v8 swap issues.
shaunk
Guys I need some help here. I got a 95 mustang with no spark... I've tested and replaced a few components. Let me start from the begining. Its a 95 mustang it originally was a v6 automatic car has been swapped to a v8. The harness was bought from a 95. The engine harness, mass air harness, and computer are all from the same car. The tfi module and distributor were from another car but have been tested and I even tried new replacements.I've done all the no start no spark tests and I'm not getting the signal to fire the coil. If I ground out the side of the coil I can make it fire. Also the injectors are not pulsing and the fuel pump does not prime. The rest of the sensors show the reference voltage. The injectors show the bat voltage on the one side and the other side shows 8.3 volts?? I don't understand that. I've tested that the ignition module, coil, and distributor they all have voltage. Now the weird thing when I hook up the scan tool it will not communicate but when I turn the ignition on the scan tool completely shuts off (it is hooked directly to the battery). The injectors do not preprime either. The transmission harness is not in the car. I have the nuetral safety switch bypassed. The processor is a t4mo. I'm almost certain I have had one of these year cars run with out the trans harness. I've done it a few times in newer ones for sure. I've tested at the spout connector and it does not flash when cranked. I've probed, poked, prodded and prayed and so far nothing.
Steven
SC
Re: !995 v8 swap issues.
Sounds like the computer is dead or either not even on. Make sure the computer specific ground is hooked up
shaunk
You mean the one that comes out of the main harness in the kick panel with one red and one black wire? If so it is grounded.
Steven
SC
I believe so. Obviously the computer is dead. No spark, No fuel. Its either did or somethings not hooked up correctly.
shaunk
I've been thru that list twice and almost every other one I have found. Thanks for the link though.
