2003-2004 supercharger to 1996-1998
mustangspartan
MN
Ok ive been finding alot of supercharger setups with the injector on ebay and others for less then a grand..Would this fit a 1996-1998 cobra??? What else would you need to make the stock supecharrger work?? Are there kits on the market for this??
Magic
Some time zone
Intake ports are different! So the 03-04 Cobra setup wont work. You will have to change over to the 99up 4v heads. Or just buy a used KB kit or vortech kit for the 96-98 year Cobra.
Jrgunn5150
The head's, the front cover, the tb, and throttle cable... It's alot of part's before your done, and alot of $$$
SMOKE
QFT ... better off getting a kit for the specific year, unless you have 03/04 Cobra your parting out.
Magic
Some time zone
^^ As long as you have the 99up style heads (C-heads, Tumble port, 03-04 Cobra heads, Mach1, 99-01 Cobra, Aviator, Maurauder etc), then the 03-04 Eaton setup will work.
quikcobra
I have this done on my 99 cobra. It is the eaton swap
You will need,
heads off a 99+
03 cobra
timing cover lower mani, supercharger
balancer
better if you get the p/s lines off a 03
coolant antifreese pump,lines, resivor, mount
well theres alot if your interested email me ill give the complete list to you. but its worth it in the end
mustangspartan
MN
if i had enough for a 99 cobra right now i would pick it up but the 96-98s are in my price range with that supercharger. thanks guys hopefully next yr ill be picking up a 99 and would love to get a very detailed list of what i would need..
senior001
