2003 Explorer Issues Opinions
uncltrvlnmatt
Pa.
I have 2003 Explorer 4.0 V-6 93k on the clock.
The original issue was my wife was going to work. The service engine soon light came on and she lost powe. The original engine code when I got to her location was a PO430 catalyst system below threshold bank b. At this point the truck ran fine just no power. Found that the catalytic converter was shot. replaced the Y pipe all 3 cats. Statred it up and now I have a engine miss with 3 engine codes.
The original code was still active PO430. The new codes were PO300 Random multiple misfire detection and PO316 Misfire occured in the first 1000 revolutions.
So I pulled the plugs and the left bank cylinders 4,5, and 6 were shot the electrodes were burnt and the gap was .075-.080 on all 3. The right bank cylinders 1,2, and 3 gap was good but electrodes were showing signs of wear.
Replaced the o2 sensor on the right side and the PO430 code went away.
Gapped the spark plugs to .052 replaced plugs and wires, used dielectric grease and never seize. I still have the engine miss but it is not showing any engine codes at this time.
I have good spark, and good compression in all cylinders between 180 and 185. My thoughts are a fuel problem. Opinions/Thoughts?? I'm goint to take it out for a ride and see, it only has a miss 2000 RPMs.
U
uncltrvlnmatt
Pa.
Truck runs smooth at 1200-1500 RPMs+ and seems to have good power. But it feels like it is running on 3-4 cylinders at idle. Also both the PO300 and PO316 codes became active again after a few minutes.
My thoughts are it is a fuel injector problem.
2slo95fiveoh
Lawrence, Kansas
I would agree with your hunch on a fuel problem.. My experience with bad Cat Converters is that some original problem with the a/f ratio
caused the Cat to become plugged up. I would check your fuel pressure... It almost sounds like your fuel pump is
leaning out, causing your computer to pull timing (for safety), feeling like a missfire.. A fuel injector is possible, but I have seen
more fuel pump problems than injector problems.. I literally just finished a similar problem on a 04 Ford Escape, and it was doing the same thing..
U
uncltrvlnmatt
Pa.
I made an appointment to have it looked at on Tuesday. I decided this morning I was not going to throw money at changing parts and hoping it will be fixed.
U
uncltrvlnmatt
Pa.
The intake manifold had a bunch of pin holes in it next to where the egr valve outlet tube is.
