3.73s to 4.10s, improvement or waste of money?
justinschmidt1
I was just curious to how much gears actually helped everyone in the 1/4 mile.
How much of a differance would there be going from 3.73s to 4.10s in a auto 96 gt?
Anyone switch from 3.73s to 4.10s and see an improvement?
Steven
SC
I did.. 4.10s are 20 times better then 3.73s.. i had 3.73s for a week, and got rid of them quick for some 4.10s.. lots of improvement
J
justinschmidt1
that was fast...your auto im assuming?... any before and after track numbers?
Steven
SC
lol i just happened to click at the right time.. and i'm a strong believer in automatic with 4.10s.. well the thing is with 3.73s your not going to have as much trouble off the line like i do sometimes, simply because i spin more. 4.10s is better if you have a stall speed, where as 3.73s are better if you are going to stay bone stock 5 speed/auto and not do much more. If your like me and eventually plan on a stall/5 speed swap, 4.10s all the way.. simply because your 60ft times will be a great deal better and alot of times a race is won off the light, unless your car pulls at half track
J
justinschmidt1
Yea..only problem is I just installed sportlines and I dont really get traction with street tires..Id probably be better off buying a set of slicks or drag radials.
get the 410's I have had TWO GT's with automatics in the sn body style .....a 96 and most recently a 98 and BOTH of them had the 410's put in. ITs day and night between the two, its going to be one of the best mods you can do. You can cut a few TENTHS off your 1/4 mile time not to mention the SOTP feel :)
J
justinschmidt1
going from 3.73s to 4.10s?... I have 3.73s
ewwww, no mine was from 327 to 410,............if your going from 373 to the 10's I dont know how much of a benifit you will get ( although your going to get some for sure )
J
justinschmidt1
yea...but I doubt its enough of a differance to spend the cash on it.
Im thinking about nitrous at this point...stupid 2v 4.6
My dad believes that nitrous is the devil or something....but if its tuned right and I only run 75-100 shot i would imagine I wouldnt have any problems right?
voidfinger
shit, if i wasn't going to get it tuned I would run 100 shot. If your getting it tuned for the nitros step it up to 150 shot. Thats what i'm looking at for the 4v i'm putting in. you might want to stay around 125 though, i've heard of no problems with that much... just make sure to get all the safety stuff.... fuel pressure switch, window switch, WOT switch, so on and so fort. Keeps from killing the motor and more often than not... the intake. lol.
not ryin to hijack the thread here but would i like the 4.10's in my 98 5 speed???
the only thing is i drive to florida every now and then to visit my girl, and i dont
wanna be runnin outrageous RPM's and get crappy gas mileage. should i go with
3.73's???
Steven
SC
3.73s would be fine with a 5speed.. theres only a couple hundred rpm difference between 4.10s and 3.73s with a 5speed
gt96stang
I hate my 3.73's... and then again it's only about 200 more rpms if you have 4.10 vs 373's..
xsoutherngun89x said:
forgot to add im runnin stock 2.73's
If "I" were going to do it all over again, which I will once i tear up the diff enough to replace it.. I WILL be going with 4.30's..
Whistler98
Southwestern, Pa
I have 4.10's and the only way I am changing them is when I go to a built bottom end with heads and cams and change to a d1sc. I will still keep the 4.10's but something tells me they will be to much and at that point But I will have to see once I get to that point.
SRT Handz
4.10s are to much gear....you will get Shitty gas milage and not be able to drive on the freeway
Purple97GT
3.73's???
If I recall correct, I run 2400rpms at 70mph with a TR3550 and 3:73 gear. I think around 2500 was 75mph.
I run 8.7's in the 1/8 mile and 13.5's in the 1/4 on stock 17's.
Sn95tre
