For Sale 306 Long block in PA, TFS stage 1, GT40P heads, 1.7's,
ram360
It looks like I'm pulling the motor from my 94 cobra and it's not going back in. It is still currently in the car and you can hear it run, unfortunately you cannot drive it due the the fact I have an issue w/ either my trans or rear. Since I'm already doing that it just going w/ a different engine while it's apart. It's my only reason for selling. Doesn't smoke, knock, etc. I have taken it on a few 160mi round trips a few times this year w/o issue. I did not build it but I will tell you what I know as I know the previous owner of it.
The engine came out of 88gt back in 2004. The engine must have been a replacement motor, it had e5te heads on it and right by the dizzy hold down it has .030 stamp on it. The gt40p heads were purchased brand new,along w/ trick flow springs , and the tfs stage 1 cam in it and also added in 2004. I cannot verify the mileage but if I had to put a number maybe 30,000 miles. I can do a comp test before I pull it. I'll add an idle vid of it shortly.
50 oz balance
Stock block (.030 reman motor)
Stock crank & Rods
Gt40P Heads (have no port work) converted to stud mount rocker
1.7 rockers
Trick flow springs
TFS stage 1 cam
Long block I'll let go for $1200
Just add your intake and engine accessories and your good to go.
Located near wilkes barre pa 18704. Not interested in shipping. Come get it.
Idle vid
R
ram360
I'll help you drop it in. I may literally have everything you'd need to convert that car to a v8.
R
ram360
Let me know if something changes man. Added an idle clip to my orig post.
R
ram360
Going to pull it from the car within the next week or so. Will add pics once it's out.
R
ram360
Is it out yet?
Not yet, my time is really limited so that's the reason for my two week time frame but I will update you guys as soon as it out. Win if your interested I'll give you a pm first. That being said once it's out I will pull the oil pan and vc's and have pics to show whatever I can w/o tearing it down.
R
ram360
Awesome ! Busy season is almost upon me :) $$$$$$ to be rolling in soon
ha, can't complain about that. Alright man, I'll PM you when it's out and you can decide if you want it first. For some reason I didn't realize you still had your car? Weren't you parting it awhile back?
Win
Kennesaw, Ga
I'm on my 7th mustang ... I have a 95 DFG vert now.
Yes I know it needs to be lowered, tint, vinyl dye the top.....most likely the Full Cobra front and rear brake setup I have will go on it.
Jerry santos
