351 block in a 95 mustang
Phantom
What transmission, driveshaft, and motor mounts would be needed to go with a carbed 351W block in a 95 mustang.
Need Help thanks.
P
Phantom
So if i go 408 stroker and a c4, i can use my same motor mounts and drive shaft from the fuel injected 302?
thanks
Paul
Yep. Hood clearance will probably be an issue though. Especially with the carb.
stang94X
well the c4 is shorter isnt it and need a spacer to use the stock drive shaft right
LAFENATU
Paul can you do a 351 write-up??
There are probably 25 diff. 351 posts on here lol..
Paul
You're right, I really need to do a comprehensive 351 swap thread. I'll put that on the list.
BlkoutGT
MO
there used to be a Tech section at the top that had alot of info on the swap... I havnt seen it since the server swap though. Did it
get moved or somthing? But Paul making a write up would probably be the source of info
