351 block
Crone
I know this question is over asked but it's difficult to search for the answers I need. I've been trying to look around for a 351 block to build up. And a junk yard block is seeming to be my best bet. So I know I'm looking for a 351 windsor, but It needs to be a roller block or something like that? What other kinds are there? And would I be able to get one out of an old f250 or something? What years would I be looking for? It's going to be completely stripped down so I'm not worried about what will swap over easiest, if that matters. I don't mean to sound like such an idiot but you gotta learn somehow lol :dontknow:
LAFENATU
You don't need a roller. A Flat 351 will work just as good.
The 1st gen lightning motor was a flat 351.
If you want a roller 351 I believe you have to look for a 94+ Econoline 351....don't quote me on that.
C
Crone
What is the difference between a flat and a roller? Is one better then the other...or cheaper!? Is that the cam type by any chance?
5.0kid
yes, that is the cam type. One motor has a hydraulic roller type camshaft, which is what our 5.0s come with. The other has a flat roller cam, which is an older design, but is usually able to take more of a beating and is many times cheaper. With the flat cam, I think you may have to go with some different valve springs than what usually come on aftermarket heads (unless you buy knew and order with that type).
either will work...
LAFENATU
The roller can run a much more radical ramp on the opening and closing side of the cam.
C
Crone
Thanks guy's!! There's so many differences with how long this design has been around it gets confusing lol
Paul
If I did it all over again with my Windsor swap, I would've gotten a roller block.
LAFENATU
That's a great reason.
Lack of information, this post has it.
lol...why Paul
btw: just bs with the smart alec comment.
Paul
Just because you don't have to deal with reduced base circle cams or expensive retro-fit lifters.
C
Crone
Is there an easy way to tell the difference between the block type?
project94
doesnt the bronco have the 351w option? i know that when i was looking for parts for mine they asked me 302 or 351.
C
Crone
Does the roller blocks end in a certain code or symbol? something that would be easy to identify while I'm out there? Thanks for the great info guys!
Paul
"F" is the letter for the 90's decade. So a 94 block would have "F4" in it.
2slo95fiveoh
Lawrence, Kansas
Wikipedia says: "Generally the 1969 to 1974 blocks are considered to be far superior in strength than the later blocks making these early units some of the strongest and most desirable", but they didn't specify about when the roller 351W came about.. a couple threads i glanced
over said "1994 was the first Roller 351W engine), but i have yet to see actual documentation about it.
Paul
The earlier blocks are stronger, but it's not real likely that most folks are going to split a Windsor anyway - which is why I say I'd do a roller block if I did it all over again.
Magic
Some time zone
And save a boat load of money from using those super expensive link-bar hydraulic roller lifters, IE. Crane, for hyd. roller cam setup.
Paul
You can use OEM 5.0 lifters. I did. I just drilled/tapped the valley and installed the 5.0 spider retainer thingy.
