94/95 TB options
junk racing
Wylie Tx
I have owned a few mustangs but never a 94/95. I noticed the sn95s have a 45 degree elbow and the biggest tb i have found is a 75mm aswell as the 45. I am building a dart 363 afr 205s solid roller with a D1 on max boost. Are there any options for me to go bigger. I talked with the guys who make the spyder intakes (cpr) and well on their website it says bolts in stock location, But when you talk to them to verify that they are not sure which elbow it needsthey offer 3. After that i decided against it if they make them and cannot be for sure. I bought a fox lake ported TFS-R for it but if theres something better id like to go that route. Thanks guys
castine917
wyoming, mi
Depending on your goals the fox lake ported tfs-r that you chose may be perfect.
If you were using a "power elbow" the choice of which one you wanted would have depended on the style of carburetor like intake you chose.
Steve Morris Engines would likely suggest a carb style intake and elbow. http://www.stevemorrisengines.com/engines/sbf/1800hp-sbf
Nelson Racing would likely suggest a custom billet intake. http://www.nelsonracingengines.com/parts/Ultimate-in-Fuel-Atomization.html
When Matt Glover built his foxbody 363, afr205, ysi,e85 combo that put down 1014 rwhp he used a systemax. That would be foxbody TB not needed example. http://www.youtube.com/watch?v=1ry3tBCnzgI
My neighbor's fox ran 9s with trickflow headed 306, ysi combo used a tfs-r. http://www.streetfire.net/video/jims-new-personal-best-run_193941.htm
My 95 SteveMorris 363, AFR205, combo is still being finalized but, tfs-r 75 deemed sufficient with plans of a ysi. Whether I do foxbody TB conversion or not hasn't been decided for sure yet. Still may switch to a procharger too.
95opal
like adder suggested get rid of any thoughts of using a standard 94-95 set up. Accufab will be the way to go for the T-bod, as for intake that's up to you. Victor, spyder, ported holly, or custom
