95 obd2 issue
RAU03MACH
NEW MEXICO
The one under my dash dose not work
I tried my blue tooth scanner on it no go
So on 5.0 it doesn't respond
Well I'll be covering over to the megasquirt computer soon
And the EEC won't be needed
5.0 has the connector as they were expecting to switch over sooner than later, but they are not connected to anything
Kyle89
Kyle89
1994-1995 V6 Mustangs are in fact OBD2 and have a connector under the dash. The 5.0 cars do have the connector, but it's not functional. Need to pull codes on those cars under the hood.
The fuse for the OBD2 diagnostic port is also the same fuse as the cig lighter, so check to see if this fuse has blown. Yellow one highlighted below
It's a very primitive form of OBD2 so don't expect to see a lot of PID's like something made in the last 10 years.
I’ll check and replace anyway but it looked good before my first fire up
Kyle89
Kyle89
Off topic but does anyone know where I can order the transmission cooler lines ? Mines leaking at the trans and before I fully bolt my exhaust on I need to replace them and can’t find them anywhere
RAU03MACH
NEW MEXICO
i dont think you can get them new
MPS
might have a good used set
if you have the right fittings you could make the lines yourself
seen one guy do it with braided hose and fuel fittings
Kyle89
Kyle89
MPS
I was worried someone would say this lol do you know if the 5.0 lines are the same ?
RAU03MACH
NEW MEXICO
Ya I collected a few ford tools
Rotonda was the manufacturer at that time
But ya be surprised by what you run into
Kyle89
Kyle89
I got my obd2 working but I’m still having rough idle no misfire codes smell of fuel bogging down in gear no power no codes any thoughts
Mustang5L5
What data does the obd2 give you for live data? Those early systems were pretty basic.
Will it give you short term and long term fuel trims? There is certain live data you can look at it, and some you have to do the old fashioned way like checking fuel pressure
