99 mustang gt
alex302
howd you get the top panels off and what did you paint them with? ive been wanting to do the top of mine black as well. i was thinking about getting a wrap but i like your look.
+1 on this ^^
Very nice GT!!
O
onelow2v
step 1:take off the door seal rubber
step 2:take off the roof rail channels which are held in with (15 throx bit)
step 3:then remove the the (8mm bolt) from the sail panels behind the fender
step 4:after removing the bolt remove the screw from the sail panel their should be (3 to 5) screws holding it in
step 5:grab firmly and pull up on the front sail panel to remove it
step 6:remove the seat belt from the top of the interior trim panel
step 7:take the screw out that holds the coat hanger hook in place
step 8: pull the interior trim piece out of the car behind the trim panel their should be (11mm nuts) remove the nuts then get on the out side of the car and pull the panels off
then you have successfully removed the sail panels to paint the panels or wrap them
hope that helps
Musturd
Need to take the rear interior pannels out and they unbolt just like quarter glass
mavisky
Atlanta, GA
You're seriously making me want to go out and by coilovers for mine and put it's dick in the dirt.
O
onelow2v
new plate
seats installed waiting for harnesses
Cpotts13
Biloxi, MS
did you notice a difference with the aluminum ds? Was it a hard install? Can you give me a brief run down if you dont mind?
