From everything I have read you can just take the spring out and not put one back in it's place. Is that correct?...and if so I would like to here from some people who have done it. Any ill effects and is it worth doing? Yhanks in advance. :thumb:
Bigdaddy said:From everything I have read you can just take the spring out and not put one back in it's place. Is that correct?...and if so I would like to here from some people who have done it. Any ill effects and is it worth doing? Yhanks in advance. :thumb:
PM sent :thumb:J.R. said:Bigdaddy said:From everything I have read you can just take the spring out and not put one back in it's place. Is that correct?...and if so I would like to here from some people who have done it. Any ill effects and is it worth doing? Yhanks in advance. :thumb:
Not entirely. I mean you can, and it won't adversely effect your trans, but it will adversely effect your shifts. There are some accompanying holes that should be opened up in the separator plate. How you use the car, and what you will put up with from it determines exactly how you modify the valvebody.
To get you started, go to TCOA and look under their tech articles for the "jmod" it should get you plenty of info to get you started. Or feel free to ask me any questions you might have.
http://www.tccoa.com/articles/tranny/index.html
Bigdaddy said:That is what I read. I just wasn't sure if you could remove it without doing everything else. I allready have the pan off because I'm replacing the filter befor I replace the tranny.
