After new MAF, new IAC sensor, new plugs (.042) and wires, my surging idle problem is back. Hangs anywhere from 2000rpm to 1500rpm. Sometimes it drops down to the usual idle (950rpm) on its own. Other times I have to goose it, which of course causes the rpm’s to increase but after that it drops down.
The IAC sensor is clocked correctly and is set in place with a grommet and sealed tight with high temp silicone sealant.
The MAF is a new unit that came calibrated for 24lb injectors (I run Accel 24lb)
Plugs are the brand and # that are recommended by AFR for my 165 heads. And the wires are now 8mm with 90* boots where needed because one of the MSD 8.5’s got fried on the exhaust manifold.
Car also stalls due to no fault of mine. It has stalled in two different scenarios: 1.) being when I put it in reverse; and 2.) when I’m stopped (for example at a stop light) and the hanging idle finally drops down but drops too far and stalls the motor.
I feel like I did everything right with the installation of the new parts, so why has the hanging idle returned?
1,000 threads on this but wanted to lay everything I did out in case anything sends up a flag.
Thanks everyone!
Thanks everyone!
