acting
RED guy
hi guys
well i noticed something in my stang at morning it dont start from the first it fire up and die second turn it start up idling strange for 2 seconds then everything fine, at take off slowly it bogs down some time and feel its heavy but after the RPM going up it launch fine.
I did complete tune up before monthes also
it has only exhaust K&N filter and 4.10s
what do you guys think about it?
joekd
Ct
Could also be a leaking injector which is causing it to puddle fuel
Start by cleaning the IAC though, cheap and easy fixes first
R
RED guy
guys i cleaned it but now the stang wont start i crank it start and die if i put my foot in the gas pedal and rev it up ok if i left my foot it die again
please help
DropTopPony
South Jersey
Did you clean it good? Is the plunger mechanism stuck inside it? Maybe it just needs a replacement. I know its probably tough to get parts over there so maybe try cleaning again with carb cleaner to get any carbon out.
Have you tried a new fuel filter? Clean your MAF, K&N air filters can have too much oil and cause issues in the intake tract.
joekd
Ct
Are you sure the vacuum line for the IAC is connected and does not have any cracks or leaks?
tazmanhawaii
Sounds like the MAF sensor may need to be cleaned. There are some great write ups on how this is done. Just Google it or search this site.
