I bought my 95 GT about 4 months ago with the air conditioning not working, now the weather is getting hotter I want to get it fixed This plug below has been disconnected from the compressor, I assume that's where it's meant to go ? But I connected it and the clutches are still not engaging on the compressor Also not sure if it's related but there is no air coming out of the vents above the control switches but there is air coming out of the dash vents Is the fuse for the air conditioning in the box next to the battery ? Any idea which one it is ? Any ideas ? Thanks
The AC clutch gets its power from the CCRM. I would pull the connector and see if it has voltage going to it.
Air coming out of the vents could be a vacuum issue. I had the same issue with mine and a vacuum line broke on the passenger side engine bay that leads the the HVAC unit.
