Air vent selector issues
Adam Vinnicombe
Hi all I have a 2001 mustang GT and am having issues with the air vent selector. Now if I select face the face vents work, if I select off the air vents shut off. Now if I select feet, feet/window screen it just defaults to window. Any ideas on why I can’t select the feet or feet/window screen opinions?
Many thanks
Adam
PS. I should also say it does work correctly on some occasions
evilcw311
Most Evil Member!
Louisville, KY
You have a vacuum issue more than likely
Adam Vinnicombe
Adam Vinnicombe
Yep I sure do. I took the control panel out and when the face vents are selected there is no noise but if I select any other settings you can hear air hissing out of the rubber unit on the back of the unit
evilcw311
Most Evil Member!
Louisville, KY
Sounds like you found your problem.
Adam Vinnicombe
Adam Vinnicombe
Does any know where the red and blue vacuum hoses go?
I’ve found out that the black hose is the source and there is a vacuum there. The yellow hose goes to the vacuum motor just behind the radio and there is vacuum there if I select the face vent, the white hose that goes to another vacuum servo/motor on the right hand side behind the glove box also has vacuum going to it but only when I select the MAX AC setting. I can’t find where the blue and red hoses go
jeanfltns01
