Alternative to Eibach rear sway bar?
Daryl
Somis, CA
Visually, it seems to sag down near the wheels, leaving very little ground clearance. Is there (or are there) alternatives that don’t have that “sag”, or are they all pretty much like that?
Thanks!
skidoo
Thanks!
Picture? I bought the Ford Motorsport kit that had shocks, springs and swaybars and it sits pretty tight. I'll try and snap a picture later on.
Sent from my Pixel 5 using Tapatalk
skidoo
This is the Ford Motorsport one, not sure on distance to the ground.
Daryl
Daryl
Somis, CA
Seems like they could easily take 1.5 - 2” out of that “sag” design.
skidoo
Are those Maximum motorsports lower control arms?
Daryl
Daryl
Somis, CA
Hmmm, yours had a bit of sag. Not as much as mine, but still some. How much ground clearance?
skidoo
4" pretty much on the nose. Rubber is 275/40-17
I wonder can you drill new mounting holes on the LCA tabs?
Daryl
Daryl
Somis, CA
I’ll have to check if there’s room, but that’s an option. My rears are 315/35x17
PinkieT
Cleveland
The cheaper aftermarket LCAs have bolt holes for the sway bars that make them lower than stock. The stock arms mount the sway bar right in the middle, the aftermarket ones mount them on a tab a few inches lower. I know, I have the same problem with my Hellwig bar on my tubular control arms.
Daryl
Daryl
Somis, CA
Alright, so after I replace the speedometer gear ( so hopefully my speedometer, odometer and cruise control start working again!), I’ll see about hoisting the ass end of the car up and checking for solutions regather sway bar. Will also attempt a video of a cold start up soI can post and get feedback.
joe65
20200819_195157.jpg 20200819_195157.jpg Daryl, almost looks upside down. weird. Maybe not and its just the angle.
here's what mine looks like. stock sway bar.
TrickVert
Woodland Park, CO
Daryl, sorry for the late reply. Here's a pic of mine during installation. I'll try to remember to take another shot of it on the car and on the ground tomorrow.
By the way, those are MM non-adjustable lowers.
Daryl
Daryl
Somis, CA
Thanks, Trick! Anxious to see the pix once it’s on the ground. What year is yours?
DKblue98GT
I have the Eibach bar/MM control arms and although it sits low I have never had an issue with it hitting anything. My K member brace however is another story...
Daryl
Daryl
Somis, CA
DkBlue,
I’m the opposite! Up front,K-member’s no issue. Out back... I’ve had a couple of light scrapes: one steep driveway and a rock in the road. Looked small enough to go over, but surprised me it wasn’t. But that’s it. So far!
Jerry santos
