Another cooling fan issue
shorty
fan will not come on
Recently replaced the intake and i removed the rad, and cooling fan
verified fan runs with 12volts directly on it
replaced the CCRM still nothing.
from what i can see all connections are back in place.
what im really wanting to find is the complete setup showing what controls what and what connectors send power
checked the large fuse, checked out ok
I got to be missing something simple
Roy1
Appears to be like your car over heated. Need to check your hoses. Or your radiator may be dripping. Best to take it to a auto mechanic to be sure. Because if you are not familiar with the repairing of the car then I don't think that you should touch it up.
rz5.0
Great state of TEXAS
Check and make sure you have power to the number 3 and 4 pin on the plus going to the ccrm.. They have small numbers on the plug..
BigBore96
What year car do you have? Try grounding the fan and see if it turns on. I do it in all my mustangs to keep the fan on whenever the key is on.
94/95 is super easy. 96+ is easy but more annoying as you have to remove some interior panels to get to the wire you tap into.
Once im home ill post up which wire you would tap into to ground it out and turn it on. Not easy on a phone lol.
