Any Ideas
BillG
Hickory NC
Anyone have any ideas what might hook to this. It’s on the firewall. The black thing with white tee is what I’m talking about.
white95
Apex Junky
Admin
Prairieville, LA
Evaporative Emissions Purge Solenoid/Valve specifically..
I believe that one line connects to a vacuum source and the other to the charcoal canister in the passenger fender.
Generic diagram:
evilcw311
Most Evil Member!
Louisville, KY
That’s exactly what it is. Are you keeping emissions on the car or deleting??
BillG
BillG
Hickory NC
For now keeping it. Once running and cleared it will probably go bye bye. I may have to look for canister cause I haven’t seen on while working on it. Still trying to figure out the one on the bottom of plenum. Figured this might be it.
Burninriverdiver
If you look at the photo closely it looks like it is already connected to the hose running to the inner fender. I think you just need to run a tube from the other side to the back of your plenum
BillG
BillG
Hickory NC
Thank you sir you just gave me the answer I was looking for. Got door panels yesterday and smog pump at advance should be there this morning. So if all goes well I should be real close today to firing it up.
