Take apart your EGR and solder or JB weld the plunger 1/2 way down works for most. You can buy a plug adapter for it on ebay also if you want to spend $$. Good luck.
Just get the plug adapter from ebay if you don't understand what they're talking about. IMO on our cars it is kind of pointless to delete the EGR unless you're doing the fox TB conversion. You don't lose any power and you can still keep the EGR while deleting the smog pump and crossover garbage.
y r u disabling it ne way? i tried the egr eliminator and it didnt work, i ended up with the check engine light. but i looked into it some more and its not doing anything at WOT. only at idle, so its not robbing u of n e thing really.... except the cleaner look i suppose...
