AODE Questions
russ8825
NY/FL
I just got some questions about the AODE in my 95 gt. Whats the max hp/tq these trannys can handle with an aluminum driveshaft?
russ8825
russ8825
NY/FL
Would a 4r70w require extra work to make with the 95 computer system? From what I've been reading, the AODE and the 4r70w are different as the AODEs were only used in 94-95 then they switched.
toyman
They are the same except the 4R70W has a wide ratio gear set. (slightly higher gear ratio for first 2.84-1 vs. 2.40-1 and second 1.55-1 vs. 1.47-1 gears ).
LAFENATU
Also the extension housing bushing and seal diameter.
