So I got the car back from the body shop last week, and today I went to redo the stereo system in the car. Well, the head unit won't power up. Checked every fuse in the cabin and under the hood, none are blown. Get out the multimeter and set it for Ohms to check for resistance on the head unit harness.
When I check the 12v switched, there's no change on the multimeter when I have the key switched to ACC/ON but not cranked.
When I check the 12v constant, the display on the multimeter goes off, remove the lead and the display comes back on.
Thought it might be a bad crimp so I pulled the head unit harness and check directly on the car side harness, same results. I'm not sure how to physically trace back the stereo harness, I lose sight of it, and I can't see very well up under the dash.
I need to call the body shop tomorrow, since the radio powered on before I handed them the car. They had to remove the whole front end to inspect in behind before replacing the bumper cover and repaint the passenger side fender.
Are there any wires that could be pinched/cut/melted as a result of taking off and replacing both fenders and the bumper cover?
